Results 1 to 10 of 10
    Apr 2017
    U.K
    Default DPF Delete BMW E60 535D
    Hi All
    I recently post a file for EGR delete and got amazing responses with great quality files properly modified. Definitely some great people with good knowledge.
    Today i have got the ECU file of the same car but looking for DPF Delete / Off. Can anyone sort this out. or alternatively if you want to shed some light on where the switches might be or what maps to modify.
    BMW E60 535D
    EDC16C35
    Many Thanks you legends.
    May 2016
    Try it dpf off.
  3. The Following User Says Thank You to naprawa5 For This Useful Post:
    anonymousss (1st June, 2018)
    Apr 2017
    U.K
    What a quick reply. Legend!
    Ill try flashing flashing the ecu with this file now. Is the checksum corrected ?
    ivanmihov's Avatar
    Nov 2016
    Europe
    Here is dpf off 100% working solution
    Checksum is corrected
    Before flash this file reset dpf soot counters,delete all faults,make sure all dpf sensors are connected
    pass in pm
    don't forget thanks and rep buttons
  6. The Following 3 Users Say Thank You to ivanmihov For This Useful Post:
    Andy61088 (12th October, 2018), anonymousss (3rd June, 2018), filxomor (30th November, 2020)
  7. #5
    AVDigitale's Avatar
    Apr 2017
    Best Place in the World!
    your file try and report
    Proffesional ECU & TCU Tuning
    Petrol and Diesel Engines
    File Service
  8. #6
    Apr 2017
    U.K
    Ivanmihov What would we do without you!
    Absolute legend!!! appreciate all of your effortmate
    thanks a million
  9. #7
    Apr 2017
    U.K
    Quote Originally Posted by AVDigitale View Post
    AVDigitale You legend thanks for the map and help. Appreciate your effort mate
    Thanks a million
  10. #8
    Apr 2017
    U.K
    Hi Ivanmihov
    Just compared the files with Winols ... the one i share and the one you've posted ... theyre exactly the same with no changes, you sure you haventposted the old EGR file by accident mate...
    double check
    Quote Originally Posted by ivanmihov View Post
    pass in pm
  11. #9
    ivanmihov's Avatar
    Nov 2016
    Europe
    Quote Originally Posted by anonymousss View Post
    Hi Ivanmihov
    double check
    sorry the mistake is mine here is the correct file
    pass is the same
  12. The Following 3 Users Say Thank You to ivanmihov For This Useful Post:
    anonymousss (4th June, 2018), filxomor (30th November, 2020), pahatik (26th May, 2021)
  13. #10
    Apr 2017
    U.K
    pass is the same
    working file tested - Thanks + Rep
