tuareg (26th February, 2019)
Yes, post original.
Alientech KESS + KTAG, MagPro2 X17, FLEX Flasher, AVDI by Abrites, WinOLS Genuine Full, Maha LPS3000 Dyno machine.
motorsport (10th June, 2018)
how much filling the dpf filter you have?
FILE SERVICE
Dont know now is removal physical
so check in parameters
FILE SERVICE
I cant acces why is so important ?
important because when I cut dpf when you have after 70% filling car back to because still burn dpf.
FILE SERVICE
Mod file in attachment is tested and re-tested on many Ducato. You don't need to resset ash. Just write mode file and take car to a ride until DPF Light goes out (6-7 km).
BTW, solution is with Oil Service Resset possibility, not like many others solution
Regards,
gyapi11 (3rd January, 2019), motorsport (11th June, 2018), tuareg (26th February, 2019)
I have Ducato MJ8F3HW10W for dpf_off
Problem is that soot is more than 70%.
Can you file DUCATO-MJD8F3SW3042BN04__Dpf off crc ok.rar be my descision?
You inbox is full an i cant send you private message
Please i need solution and display clean dpf in instrument
@motorsport - Password sent in PM
I need solution Please truck smok lot
