check this memory switch
Hello everyone,
I need help for my Citroen C5 2.2 HDI 2001 edition. This is whats happen : I turned off the car and everything is OK, tomorrow i went to open the car with remote key but it does not work. So i try to open the door mechanicaly with key, in this moment the alarm of the car start and the direction lights flashing, i try to start the car but not start. I remove the battery and i leave 5 hours without battery and the same problem, i buy another remote key battery but no succes. I have try some time to reset BSI (from youtube video) but nothing. I have IMMO code and i have try to re-programming the key but no succes. I have test the remote control with frequence tester and it is OK. When i turn ON the ignition the wiper start work without pressing anything and the direction lights start flashing. But now it doesn't work because in monitor i see this message GO INTO ENERGY SAFETY MODE and everything didn't work. Any idea where is the problem or what can i do to solve this problem.
FILE SERVICE
evisdaci (3rd June, 2018)
Thanks i will check tomorrow and report
I have check and it is OK, i haven't result
Del...
Sorry!
So... now is time to use your X-431, or Delphi and see what happens with engine ECU, and BSI, etc...
And... i think you have too many cars, mate... like most of the people here...
Regards!
evisdaci (4th June, 2018), pulsar2000 (4th June, 2018)
I cant connection with engine ECU, i have put another ECU (only ECU) but the same, can't connect with engine ECU
Then seems you have some kind of electrical problem as voltechcar suggested.
Can this type of BSI virgin easly ? have any one any experience with this module
