Results 1 to 5 of 5
    Nov 2011
    Default FORD FIESTA 1999 - all keys lost
    Ford fiësta 1999
    I have the original ECU / 95040 data
    I have SECOND HAND KEYS - NOT from ORIGINAL car, but from OTHER car !
    is possible to put "key data" / decrypt in the 95040 ?
    or i MUST make NEW transponder-chip with the 95040 data ?
    Transponder recognized as Texas fixed
    ID 4C - JMA TP02/TP07
    TIRIS Data: 7E CE 81 C2 00 00 00 00 00 F3 88 7E
    TIRIS Data: 7E 7A A1 C4 00 00 00 00 00 3E C3 7E
    TIRIS Data: 7E 85 08 C6 00 00 00 00 00 E6 9D 7E
    PocketHero's Avatar
    Jun 2017
    Budapest, Hungary
    Sometimes it is not enough to write data in, coz that key doesn't work. In this cases just prepare 2 chips, and program it via OBD with 'delete all keys' option
    Nov 2011
    Quote Originally Posted by PocketHero View Post
    oke, but i do not have OBD programmer
    can TANGO do programming 2 new transponders, using the 95040 file ?
    engine will start without extra procedures ?
    PocketHero's Avatar
    Jun 2017
    Budapest, Hungary
    Maybe. This kind of Fiestas can deliver suprises.
    Just use cloner chips, and then it must be ok.
  5. The Following User Says Thank You to PocketHero For This Useful Post:
    CARPARTS (5th June, 2018)
    Oct 2015
    CARPARTS - better borrow from someone any obd tool and do it with diagnostic. I think that even elm327 with forscan do it. Transponder 4C and 4D are reusable, so you can code used keys.
  7. The Following User Says Thank You to klesk1986 For This Useful Post:
