    Default Tacho universal help with e46
    Is anyone any good with the tacho universal, I am having problems with a BMW E46 with a 35080v3
    Moderator
    PremierD's Avatar
    Jun 2009
    Quote Originally Posted by delboy75 View Post
    What kind of problem mate....?
    I have a BMW e46 on a 52 plate which i am trying to change mileage on, I have saved data from the original 35080 chip and then done a full write to a new chip then changed the mileage and soldered in new chip when powered up dash comes up code where the miles should be. If i solder the old chip back in it reverts back to the original mileage. I am using the "china" tacho universal. where am i going wrong? thanks in advance.
    Autotecno2006's Avatar
    Default E46
    try to do a manual edit in 35080 !
    Moderator
    PremierD's Avatar
    Jun 2009
    You have soldered it back to the original pads.....? Coz there is an extra set... Very close to the original ones ....
    Post dump from original + the one you programmed mate...
    CODE usually means that its looking for the CODE plug ...which it does not have....
    Mexico
    Default Help
    Hi, Im noob here, anyone knows where can i find info or tuts for universal tacho?
