Results 1 to 5 of 5
    Jan 2018
    Default VAS6154/ ODIS 4.1.3 problem with connection
    Hi guys, i bought VAS6154 with odis 4.1.3 software. Installation was easy but now when i want to connect car with diagnostics it writes : No connection with car. I have tried both wifi and usb cable. I have configurated all through VAS Config program, updated firmware, etc...but when i want to update drivers it fails and writes file verification failed. It's strange because this driver update is available only when i have connected VAS6154 to car. I really don't know what it can be.
    Thank you for replies.
    Peter.
    nil's Avatar
    Sep 2009
    Polska
    Hello
    On which operating system you are trying to run VAS?
    Jan 2018
    Hi, Windows 10. ODIS 4.1.3 VAS6154. I have installed ODIS 2.0.0 that worked perfectly without problems on Windows 10.
    nil's Avatar
    Sep 2009
    Polska
    I hope that the internet was disconnected when you upgraded. If you use clones, the internet can not be connected because in the best case you will have to reinstall the system and, in the worst case, flush the interface.
    Install Virtualbox and put Windows on it where you will install ODIS.
    Jan 2018
    Ok, thanks for help.
