Results 1 to 4 of 4
    Junior Member sufyann's Avatar
    Aug 2017
    Lebanon
    Default Ecu not replying solution !!
    Let's assume i have a car,
    I scanned all.the system only the engine ECU, is not replying.
    I've changed the ecu to make sure that the problem is not from the ecu.
    I've changed the scantool to make sure it's not the scantool.
    So most probably it is wiring.
    Is it possible to connect CAN-H , CAN-L, and power externally to the scantool ?
    Sent from my Redmi Note 3 using Tapatalk
    droidwayne65's Avatar
    Aug 2015
    North America
    Quote Originally Posted by sufyann View Post
    Maybe the ECU isn't getting the power it needs to function properly?
  3. The Following User Says Thank You to droidwayne65 For This Useful Post:
    sufyann (19th June, 2019)
    brend's Avatar
    Oct 2015
    Same where
    .......changed the scantool ......
    Give this job for another high spetsialis.
    Because if looked you discations , you nothing know about this.
  5. The Following User Says Thank You to brend For This Useful Post:
  6. #4
    Aug 2017
    Lebanon
    Quote Originally Posted by brend View Post
    Hi bro , by mistake i saw the post,
    I did it, its not a big deal
    Sent from my Redmi Note 7 using Tapatalk
