Results 1 to 7 of 7
    Stelaras26's Avatar
    Nov 2017
    Skyrim
    Default Bmw m3 e46 Corrupt dump
    Hello to all..!
    Can anyone check if this dump is corrupt??
    Does anyone have any dump that i can use??
    I tried to change vin to WBABS11000JX62484 and then dash went to PPPPPP
    ISTA P cant code it,neither does ncs expert
    this file is not ok. what tool use you to read?
  3. The Following User Says Thank You to IchBins For This Useful Post:
    Stelaras26 (10th June, 2018)
    Cllau's Avatar
    Mar 2017
    where friends need me
    try this.............e46 35080
  5. The Following User Says Thank You to Cllau For This Useful Post:
  6. #4
    Stelaras26's Avatar
    Nov 2017
    Skyrim
    Quote Originally Posted by IchBins View Post
    The file before was ok,until FVDI 2018 destroyed the dash dump..
    With xprog and a good file i believe i could fix it.
    Jun 2011
    Northamptonshire, UK
    You need an image that is from the same hw and Sw numbers as your own.. I believe they are hw 16 and Sw 15 from looking at you label but it is very difficult to make out as the picture is really blurry.. I am not sure what version the 2 above post is but if correct one you should fine once written with xprog.. you will need to correct the chassis number and the mileage.. but to initially get it up and running you don’t need to..
    Sent from my iPhone using Tapatalk Pro
  8. #6
    yes, best way is desolder chip and read with external programmer
  9. #7
    Stelaras26's Avatar
    Nov 2017
    Skyrim
    I read the file with xprog ...
    i erased it.and i wrote the file that Cllau sent me..
    but i dont know how to change vin,kms and all this...
    Are you able to help me?
    ΕDIT...I found out that km's are the two first rows,and vin is in 02E last 7 digits...
    Thanks everyone..
  10. The Following User Says Thank You to Stelaras26 For This Useful Post:
    Cllau (11th June, 2018)
