Maybe this will help you. Looks correct.
I have than read and write this ecu: A 646 150 15 72 / CRD.11 OM646 EVO.
I have a doubt with the pinout. I have seen an image in this forum many times, but it does not convince me. I think it's for another machine. Not for ktag.
I want to read it with ktag, I have the supposed adapter for the ktag. I have made an outline of the adapter's own pinout, but I do not know if it is correct. My adapter have two pins are connected to Pin 6 (GND).
Someone who has already read and written it with this adapter, can I verify it?
This I've seen this picture, but those connections do not know what machine they are, but I do not think it's for ktag , with ktag you have to make only one bridge this picture shows two.
someone can see the pinout this adapter. This adapter is inluide in ktag clone and original. Thanks.
i have used the adapter on clone ktag, only insert on bdm port... no soldering, press only hand.
if you won, send me on pm your phone number and i send video.
alcorte (11th June, 2018)
but I would like if someone who has done it, can look at the pinout, to compare it with mine, that I have uploaded in post 1.
The pinout than I need is:
The adapter 14AM00T02M or Adapter 14AS00T04S
