Hi I have the spanner light on, no service due next service in 18000 miles and no codes show on my basic obd reader. does anyone have any idea what it may be or mean?
Any help is much appreciated as I have an MOT at the end of the month.
did you try to do service reset again...? just try...![]()
I done the following listed below 3 times even tho there is no service due message I clicked across until I reached the service miles which is at 18000 miles but still have the same old spanner light.
1. Switch ON the gnition, don’t start the vehicle. For cars with keycard ignition, insert the card, then push & hold the start button for 5 seconds to turn on the dashboard cluster.
2. Push and release the button on the end of the wiper stalk until the Service Due Now message appears on the display. Some models have 2 buttons, which cycle through the options in opposite directions, either button can be used in this case.
3. When Service Due Now message is displayed push and hold the same button located at the end of wiper stalk.
4. Now the Service Due now will start to flash after that the display will change to the new service interval and still flashing.
5. Keep holding the button until the display stops flashing.
6. Done, have managed to reset service light indicator
