Results 1 to 8 of 8
    Jan 2018
    Jemen
    Default EDC16C34 - Peugeot 307 SW - EGR OFF
    Peugeot 307 SW, 1.6 HDi - 109HP, engine: 9HY - no FAP
    0281 013 332 / SW 1037374179
    I need to disable EGR in such a way that I do not disconnect the plug. Did I do it right?
    Jul 2017
  3. The Following 3 Users Say Thank You to diagauto741 For This Useful Post:
    ayoubgt75 (10th June, 2018), BasilKlyev (17th July, 2018), oliva (10th June, 2018)
    Jan 2018
    Jemen
    The file is similar. In this case, do not I have to disconnect the plug?
    Jul 2017
    Yes Do not disconnect the plug
  6. The Following User Says Thank You to diagauto741 For This Useful Post:
    br556hre's Avatar
    Quote Originally Posted by oliva View Post
    In your .ORI map ECU version is different: 1037393455 C35387B
    Did it work writing new map with other version software?
  8. #6
    https://t.me/pump_upp
    Here try disconecting the plug pass in pm
  9. #7
    press thanks and reputation buttons for pass
    try at your own risk i dont advise using a diferent dump on your ecu.............
  10. #8
    br556hre's Avatar
    It looks initial version 1037374179 can be upgraded to 1037393455 in that case just one 74179 copy remains in flash with additional 3 copies of 93455.
    Not sure why but it seems ECU uses (executes) last copy of software found in flash?
