    Dec 2017
    Default I want to read 68hc11
    I have a punto sporting ecu
    Iaw 18fd.5z
    What equipment do you use to read this eprom?
    I have seen xprog and USA? Any help greatly appreciated!
    Sent from my ONEPLUS A3003 using Tapatalk
    figani's Avatar
    Feb 2018
    47 45 52 4D 41 4E 59
    You can read it with xprog... in any case...
    Most of them you can read on board...
  3. The Following User Says Thank You to figani For This Useful Post:
    Rosita97 (10th June, 2018)
    Dec 2017
    Do I solder to the pins on board on chip? What can be used to do that?
    Thanks for the reply!
    figani's Avatar
    Feb 2018
    Yes, you can solder it on pins... When you open Software and click on device... New window open... Choose MCU... And the one you will read... On the left side you will get connections... Click on connections, and you will see where to solder and how to connect with xprog...
    Dec 2017
    is there anyway i can read a hc11f1 without a xprog? is there any adpater to turn a dip28 to plc68?
    t77's Avatar
    Poland Lodz
    Yes u can ...build its own interface for motorola uP Motorola Cracker
