Results 1 to 4 of 4
    Jun 2018
    Question Need help in disassembling 9S12XDP512 bin file
    I want to use IDA Pro to disassemble a 9S12XDP512 file to learn reverse engineering. The flash of this chip is divided into 32 pages (16k per page), their addresses are mapped to the same space (0x8000~0xBFFF). How should I set it up in IDA Pro to disassemble it correctly?
    Thanks for all your replies and help.
    Quote Originally Posted by gxdiag View Post
    how far you got with this ?
    Jun 2018
    Quote Originally Posted by g0tcha View Post
    I try to disassemble it manually. The experience is not good because there is no correct cross-reference.
    Feb 2011
    Greece-Athens
    You need to upload the file with offset and then use a script to define the segments
