Results 1 to 9 of 9
    Apr 2010
    Default BMW EDC17C50 DPF off & Vin Change
    Hi guys, ive been a member for some time now but ive never really posted, just watched from the shadows, seems a really knowledgeable place!
    Im after some help with a 2012 318d E91, Ive swapped the DME as the old one was damaged, ive written ISN to the new one but donor Vin still remains. The car starts and drives as it should, but it needs DPF deleted & im not sure where to find the switch for DPF off, and also would like to change the stored vin in the DME if its possible. Ive read the files with Ktag clone if that matters and attached. Any help is much appreciated!
    PelsonBMW's Avatar
    May 2020
    Eu
    Its EDC17_C41 not C50 , DPF off , Vin changed , CHK OK , pass pm
    thx and rep after check
  3. The Following User Says Thank You to PelsonBMW For This Useful Post:
    PumaNoob (17th September, 2021)
    Apr 2010
    Thanks Soooo Much, i will try it now and report back!
    Apr 2010
    The file was completely wrong for my DME, it was from DDE 8 519 667, mine is DDE 8 518 268. No communication with DME, so I had to do a recovery. Thanks for trying though. Can anybody else tell me where the DPF switch is in EDC17C50?
    Many thanks
  6. #5
    qni666's Avatar
    Mar 2019
    Bulgaria
    Quote Originally Posted by PumaNoob View Post
    Many thanks
    38832C, 38832E is switch address i can remove it manualy dpf not only switch, but i cant change your vin number if u want no problem
    WANT PASSWORD ? PRESS THANKS AND ADD REPUTATION AFTER THAT CAN ASK ME PASS PM
  7. The Following User Says Thank You to qni666 For This Useful Post:
    PumaNoob (18th September, 2021)
  8. #6
    Apr 2010
    Thank you, I will try that address today, I think thought there might be more addresses then just one, I found 2 vin numbers in the dump so I will try now,
    Thanks for the help
  9. #7
    PelsonBMW's Avatar
    May 2020
    Eu
    Many thanks
    the hell are you talking about ? ive downloaded your file , put it in winols , corrected checksums and uploaded here .
  10. #8
    Sep 2013
    Im after some help with a 2012 318d E91, Ive swapped the DME as the old one was damaged, ive written ISN to the new one but donor Vin still remains. The car starts and drives as it should, but it needs DPF deleted & im not sure where to find the switch for DPF off, and also would like to change the stored vin in the DME if its possible. VIN i need to program is WBAUT32000F215038. Ive read the files with Ktag clone if that matters and attached. Any help is much appreciated!
    It EDC17C41 ECU
    WinOLS5, custom files for ECU DCU
  11. The Following User Says Thank You to pike For This Useful Post:
    PumaNoob (19th September, 2021)
  12. #9
    Apr 2010
    I wrote the file to the DDE, writing successful, put the DDE in the car, and the car cranked but wouldn't start. Checked with ISTA, and no communication with DDE. I Tried to read with VVDI, no communication. Had t connect to Tricore and write original image. Fitted again in the car, car started no problem. Tried again writing your file and again no communication with DDE. So i opened the file and manually edited at the address qni666 gave, plus the vin number change, calculated chks and wrote to the DDE. Car started first time no problem. I tried writing 666 (EDC17C41) and 668 (EDC17C50), 666 took about 10 mins, and when i checked, there was no vin stored at all, 668 took about 30 mins. I had a stable 13.5 voltage and all solder connections were good.
    But all is good now, thanks all for the help, when editing the file i saw EDC17C41 written in the dump, however when i went to write to the DDE in the EDC17C41 protocol, it said it it detected the C50 hardware, also when retrieving ISN with VVDI, it connected via C50
