Results 1 to 11 of 11
    TuningInside83's Avatar
    Dec 2016
    Italy
    Default Mitsubishi Pajero IV Di-D 170 hp
    I need this original file read Ktag micro and backup
    Thanks to all
    HW H1214D56
    SW T9B2HBB22202
    SW Agg.1860A70202
    Dec 2016
    Italy
    Nobody????
    Samsara's Avatar
    I don't understand, you read it and it's corrupted or what ?
    Engine is 4D56 2.5 liters ?
    I have 1Mo size for 3.2DID , there's 1,5Mo size but don't have .
    Dec 2016
    Italy
    the engine is 3.2 170 hp.
    Ktag reads 1024 Kb files
    The file read is not corrupted, the DPF has been deleted by someone else and now it is not diagnosed by any faulty code. for this reason I look for an original file read with kess V2 from OBD or Ktag.
    thank you
    Dec 2016
    Italy
    This is file no DPF read Ktag
    Samsara's Avatar
    Yours is 2006 , mine is 2010.
    Try it.
    Dec 2016
    Italy
    Thanks but this is different file
    Dec 2016
    Italy
    can someone decrypt this .slv file?
    it should be the original file.
    Samsara's Avatar
    Quote Originally Posted by TuningInside83 View Post
    Of course because newer, Mitsubishi renew his files for each model.
    Just try it or try Nicotibi's file, it's older than mine.
    Dec 2016
    Italy
    you can not write a file with different hw and sw otherwise the machine does not start
    Samsara's Avatar
    You wrong.
    For example , i flashed L200 2015 1860B702 H18JCR59TFG3HFG39502 with old file 2010 1860B701 H15XCR59TFG0HFG09402 and i drive it for 10000Km without problem .
    It's up to you.
