Results 1 to 2 of 2
    Feb 2012
    Default Kia Venga stering angle sensor fault
    i have problem with kia venga. esp light is on and in ecu is two faults:
    c1260- stering angle sensor incorect signal
    c1261 - stering angle sensor not calibrated
    I try calibrate but not succes. I check fuses is ok. I took off steering wheel but there is no sensor there :-( only airbag tape. Where is in this car SAS sensor? Maybe in power steering? But the power steering works ok. Only ESP light.
    help me please
    regards
    Senior Member maybach_'s Avatar
    EU
    Someone with solution on the comon problem on kia/Hyundai EPS with steering angle sensor in the steering module.?
    Be allways Thankfull!
