Results 1 to 13 of 13
    Hungary, Mosonmagyar?v
    Default Jaguar S-Type 2005 odometer correction
    Hi!
    I need to correct the dash "km" in a Jaguar S-type my-2005,2.7d.
    It uses MC9S12H256VFV , 1K78X mask mcu.
    I`m attaching the original file with 198608 km. I want to correct it to 132000 km.
    Does anyone can help me?
    DK Veteran rsibiza's Avatar
    Quote Originally Posted by kareszka View Post
    Hi!
    Hey M8.
    Think your file is corrupt....its empty....shows only FFFFFFFFF
    Moderator
    PremierD's Avatar
    Jun 2009
    Quote Originally Posted by rsibiza View Post
    Hey M8.
    Did you check the the whole dump mate.... Coz its there ...at the bottom (where it should be...)
    Moderator
    PremierD's Avatar
    Jun 2009
    Hi!
    Calcs at the workshop mate....If one of our Brothers don't alter it tonight ...I will do it in the morning....
    PS.. It's a good Idea to blank the Vin number mate...( Lot of Dubious Characters in the world...) Not members Of course....
    Meat-Head's Avatar
    Quote Originally Posted by PremierD View Post
    So what about the 'O.P.W.' the One Post Wounders arn't they dubious then?
    Moderator
    PremierD's Avatar
    Jun 2009
    Could be mate.... Who knows (apart from themselves )...
    Hi!
    Thanks for reply.Problem solved ,I made calculations with Licznik4 .
    I use Ford Ecoline(9s12dt256c).KM data stored on same place and system.
    Greetings: kareszka!
  8. The Following User Says Thank You to kareszka For This Useful Post:
    paskuale (13th January, 2020)
    Moderator
    PremierD's Avatar
    Jun 2009
    Hi!
    New it was ford mate ... but unsure of the Encryption .. Glad you sorted it out...
  10. #9
    Hi!
    Yeah, but with what I could original KM I was able to experiment with it so and I was lucky.
  11. #10
    Moderator
    PremierD's Avatar
    Jun 2009
    Hi!
    Good for you mate ...Coz I would have said 28 0B...and then it would have come up error...Just working it out myself that is ... If I had used Tachosoft ...Ford Freestar ..it would have given me 28 0C...
  12. #11
    Member repairman30's Avatar
    Dump is here. 132250km
  13. #12
    GB
    Do you have the points to solder or has to be removed from the board.
    If not remove, which software are u using.
    wbr
  14. #13
    vuno01's Avatar
    Europe
    use the same points as ford aswell
