It IDE00275-Particle filter initialization,38.7457 g 38.74 g fort
romove dpf .
DPF / FAP / EGR / SCR / NOx / TVA FLAP .. etcDo not forget to press the button thanks and reputation
# Algerian #
Much time has passed since my original question was posted... Did anyone find a solution to INCREASE the value of "static" maximum speed limit using Adaptation channels or special login code?
I have heard one guy from Norway knew a method to do that but I lost his contacts
* MK100;
Hi everyone, has anyone found a solution to desactivate this option:
"IDE02632-Activation of static maximum speed limit,OFF " which for me is On.
I did not find a solution despite having put the code 27971 in the adaptation before doing the procedure with the VCDS.
I want to change this value and not the others because they are restricted to the maximum on my POLO 1.6 TDI engine code CAYB
Thanks for your reply i really need some help !
