the best solution is to put audi official service, to download latest version of software.
8E0 910 115 M
S0030 0753
0 261 S02 223
DTC ERROR
001537 - 16985/P0601/001537 - Internal Control Module: Memory Check Sum Error
I need Flash File for This ECU
Orginal soft is 0030 i hear that is possible to Write 0080
Motor 2.0 TFSI
I try to repair it by BDM and Calculate Check Sum but no Success
How old is the car?
If it is under 2 years, then Audi will put new software on it for free, if you tell them there is a error with the car, lets say, motor running wrong at idle, and you heard that a Software update will do the trick.
The newest ECU dvd from audi/vw is version 51 or 52, if you want to use a non SVM/Audi Flash update, using a not registered VAS tester.
But if the car has this error, it might break the ECU if you put new software on it using the original VAG/Vas tester, because i need to make a complete checksum control before and after update, and if the software allready have been tampered with, it will be seen, because of Audi and VWs SVM system(Software Version Management), where the VAS tester has a connection with the VAG server, to see what software there was on the car, when it was delivered, and if there have been any software updates, from a certified Audi partner.
It the current ECU software and the data from the VAG server is not the same, then they might charge you, and they problery wont do the update with any kind of warranty.
I can say this for sure, because i work at VW, Audi and Skoda.
Best Regards
ok thx ! Car is 2006 year . I try to service partner of VW
I had same problem with Golf Plus 1.6 FSI MED 9.5.1
I had done with update software with original VAS succesfully, but Internal Control Module: Memory Check Sum Error still remain after update ecu, so I'm afraid that this will not help this case neither.
I'm over of many trying to repair eeprom dump to solve that problem, but till now no success.
Greetings
Bingo
I have the same problem like bingo76, my car is VW Golf 1.6 FSI 2005 year
the VAG says:
Control Module Part Number: 03C 906 056 CB HW: Hardware No
Component and/or Version: MED9.5.10 00 7001
Software Coding: 0000072
Work Shop Code: WSC 00028 028 00001
1 Fault Found:
P0601 - 001 - Upper Limit Exceeded - MIL ON
Freeze Frame:
Fault Status: 11100001
Fault Priority: 0
Fault Frequency: 1
Mileage: 135265 km
Time Indication: 0
Date: 2000.00.00
Time: 12:55:12
Freeze Frame:
RPM: 680 /min
Load: 23.5 %
Speed: 0.0 km/h
Temperature: 69.0?C
in my car was changed ECU software to modified (chip tuning) but the car working well for 1 year
I can't erased the fault code
Do you no know anyone the solution?
Best Regards
i think there is one methode that nobody has yet tested
program the chip outsade the calculator
the best method of programming and safest
Nanu (13th October, 2013)
Isnt this fault coming from old version software? was an original VW error.
Then some tuner made 1 tuned file with this sw version...and dumped so many VW s with...that the problem still exist today.
I have this problem solved by ori VW update online(payd for it) and modified the new sw from vw...no more checksum error on this...
no,that mean desolder chip,programme in programmer and solder chip in ecu
you can't make error cks,and you don't have to power ecu to do it
I wasn't aware that was a option. Would my willem be able to do this?
if we are talking about the flash no, you will need something more recent, a wellon 980 or something like that...if you want to try to adapt the eeprom dump you can use willem...
bdm will do the job for this kind of ecu with no problem, and it has also cks included...so no need to desolder!
you may try also to let bdm do the cks, maybe it will work.
anyway, rsibiza was wright, this is the effect of using old sw tuned file...an sw update will solve the problem, but that means you will loose the tuned file...
what about mpps clone?
also what about the immo stuff? which tools get around that, and which dont? checksums?
Hi, my bad
