Results 1 to 15 of 29
    Default UPA USB in Circuit Adapter Build
    Hi Guys,
    I am looking at building the in circuit UPA USB adapter. I have seen the schematic for Bender UPA USB adapter and will be attempting this...
    I just had a few questions, Please see attached pictures and see if i have got the setup correct please?
    Also, on the left of benders schematic if i want to put serial is it still pins 1-9 on serial?
    On the right is pin 1 for serial as i have marked it?
    Can you see anything wrong i am doing?
    I'm only going to be using microwire mainly to read ford ranger 93c86 eeproms.
    Kind Regards,
    frankrayk's Avatar
    Aug 2015
    42 52 41 5A 49 4C
    I use to make reads on the 24CXX and 93CXX circuit with original UPA and use no adapter.
    If I was useful to you, thank you by pressing the thank you button .
  3. The Following 2 Users Say Thank You to frankrayk For This Useful Post:
    mikroel (27th August, 2018), ps80l (13th January, 2019)
    I think it depends... I can read 93c66 ok and even 93c86 on Nissan but 93c86 on Ford Ranger just erases chip if done in circuit.
    Kind Regards
  5. The Following User Says Thank You to Smurf786 For This Useful Post:
    rtbdiagnostic (11th October, 2019)
  6. #4
    USA
    2 diodes on P9
    can do most ic chips in circuit for me
  7. The Following User Says Thank You to alexs600 For This Useful Post:
    AndriyM6 (20th July, 2018)
  8. #5
    Quote Originally Posted by alexs600 View Post
    2 diodes on P9
    can you explain in more details?
  9. #6
    antenor's Avatar
    Here
    Try that 5NF CABLE ........
    If i help, d'not forget to press thank button!!
  10. The Following 7 Users Say Thank You to antenor For This Useful Post:
    2560172885 (11th June, 2020), alexs600 (25th June, 2018), chiorbeq (26th April, 2020), digimile (21st June, 2018), martinracing (13th April, 2020), rtbdiagnostic (11th October, 2019), Smurf786 (21st June, 2018)
  11. #7
    USA
    Quote Originally Posted by mojomojo View Post
    just like in picture above
    instead of 1 diode i use 2-3 in series
    the rest of wires going straight to memory chip
  12. The Following 2 Users Say Thank You to alexs600 For This Useful Post:
    AndriyM6 (20th July, 2018), mikajna (29th October, 2020)
  13. #8
    AndriyM6's Avatar
    Nov 2012
    2 diodes on P9
    Work for me very well with UPA Programmer-S.
    Now I can read what can't read before.
    Sent from my SAMSUNG-SM-J327A using Tapatalk
  14. The Following User Says Thank You to AndriyM6 For This Useful Post:
  15. #9
    Trstenik - Thun
    What are you talking about for God's sake ????
    UUPA can read in circuit without any "special " adapter !!!!
    Just need to adjust Vcc for in-circuit programming .!!!!!!!!
    Reducing the operating voltage to the assembly has two effects. The first is that the other components on the assembly, even though active, will present a reduced load. This is because there is less current available to interfere with reading and programming the eeprom in-circuit allowing the push-pull driver to be more effective. The second is that the microcontroller (processor), which will normally start accessing the eeprom when the power is applied to the assembly, will not start at a reduced voltage. This means that invalid data resulting from processor interference does not occur.
    Using the voltage reduction technique provides excellent results when reading or programming eeproms in-circuit.
    Regarding 2-3 DIODES in serial on PIN 9:
    With ordinary silicon diode, with conventional currents, the voltage drop in the conductive diode is approximately 0.6 to 0.7 V.
    So it means with 2-3 diodes you guys just drop supply voltage for 1.2-1.8 V from 5 V which is default Voltage on PIN 9.
    It can be done more easily if you JUST choose 3.3 V
  16. The Following 4 Users Say Thank You to mikroel For This Useful Post:
    DanielNgi (5th January, 2019), hoangtu (30th August, 2018), junmab (19th October, 2019), rtbdiagnostic (29th August, 2018)
  17. #10
    Trstenik - Thun
    Or you can use new UUPA-S Professional EEprom adapters for Microwire and I2C/ISP Eeproms which have pads for :
    SOIC,TSSOP,DIL and Pins for Inline R/W
  18. #11
    martij976's Avatar
    Use carprog original ��
  19. The Following User Says Thank You to martij976 For This Useful Post:
    narkeleptk (31st March, 2020)
  20. #12
    Trstenik - Thun
    Quote Originally Posted by martij976 View Post
    yes original
  21. The Following User Says Thank You to mikroel For This Useful Post:
    joespecies (12th October, 2019)
  22. #13
    Trstenik - Thun
    NEW EU Made i2c/SPI & Microwire adapters
  23. The Following User Says Thank You to mikroel For This Useful Post:
  24. #14
    joespecies's Avatar
    Oct 2017
    Where can we get that?
  25. The Following User Says Thank You to joespecies For This Useful Post:
    mikroel (12th October, 2019)
  26. #15
    Trstenik - Thun
    Quote Originally Posted by joespecies View Post
    From me,
    Only in this moment.
    Check PM
    Sent from my JSN-L21 using Tapatalk
  27. The Following User Says Thank You to mikroel For This Useful Post:
