Results 1 to 4 of 4
    alclot's Avatar
    Melee Island
    Default Change HDD on Dell laptop
    Hi mates,
    My HDD got faulty and I need to change it. Original HDD is western digital and I tried to change with kinstong ssd one but it doesn't plug well. Can anyone help which ssd I need to buy?
    Thanks in advance
    alclot's Avatar
    Melee Island
    Jun 2018
    nice hard disk
  4. The Following User Says Thank You to mslv For This Useful Post:
    alclot (23rd June, 2018)
    Mar 2018
    It should fit fine. The SSD is the standard SATA interface, albeit it may be a bit thinner, so sometimes you may need to fit a piece of plastic to get it closer or to sit comfortably on your motherboard.
    aHR0cDovL3d3dy5sYXB0b3BtYWcuY29tL2ltYWdlcy93cC9wdXJjaC1hcGkvaW5jb250ZW50LzIwMTQvMDgvc3NkLXVwZ3Jh.jpg
    Like this photo the SSD may/should have come with a backing plate to stick on This way it will be same thickness as a normal 2.5" HDD
  6. The Following User Says Thank You to darkadam For This Useful Post:
    alclot (26th June, 2018)
