hi is there any1 that can give me some pointers on getting my opcom scanner to work? using v1.45 and china clone 120309a cant seem to get a response from my ecu tho... astra h 1.9 cdti 150 thanks![]()
Have you got comms to the other modules in the car?
V Series TMS470 / EEPROM data - encryption / decryption, totally pwned.
IEC 62056-21 - new discussion: sonsivri.to/forum/index.php?topic=60412.0
No not had any response from the car just says initialising ecu and no response...
What do you get when you "Test Interface" ?
You might be better testing it on the bench and scoping data lines for K and CAN.
Checking Interface...
Disable SWCAN...
Switched to DWCAN...
Pin #6,#14 switched to HSCAN...
also saying no power from car but red and green lights both on...
Disable SWCAN...
Pin #6,#14 switched to HSCAN... the most ive had is the ignition lights flashing while checking interface... bit of a novice so not sure what settings etc to go for...any pointers would be much appreciated thanks![]()
Sorry i picked u up wrong there when I test interface its saying successful and v. 145 im using Windows 10 x 64...
Dunno about W10. Tried it for a short while and binned it. Total shit for diag stuff. Half the time defender interferes and screws USB comms and u cant switch it off. Try flashing an ecu when defender decides it wants to update half way thu and see what happens.
W7 x86 or XP (or W7 x64 if u specifically need it) with no AV best for any diag sw especially with opcom 139 145 154. If W7 theres a few bits to disable like UAC, defender, notifications, USB power mode etc. etc.
Dunno about yr problem tho. Is it just on that car? Have u measured voltage on obd socket and scoped data lines? (pins 6 and 14). If signals there then try another interface. They are cheap enough.
Meat-Head (17th June, 2018)
