file for you EGR OFF with CRC OK
I have a Golf 5 1.4FSI with EGR problem.
3 fault codes
17808 - P1400
16784 - P0400
17811 - P1403
I have "00" 1D2C2B & 1D2C2B. The P0400 is gone but still have P1400 and P1403
Can you help?
Thanks in advance
If you find my post helpful please hit Thanks button.
You can also hit Reputation button if you are kind enough.
CHIPTUNING, ECO-TUNNG CARS TRUCKS BIKES,
EGR OFF, DPF OFF, NOX O2 KAT OFF, SWIRL FLAPS OFF, THROTTLE OFF, MAF OFF
DTC OFF, LIMP HOME MODE OFF!!!
ADBLUE OFF, SCR OFF, ADDITIVE OFF, CNG OFF, SPEED LIMTER ON/OFF/SET
HOT/COLD START
CRC FIX - FULL GENUINE WINOLS FULL CRC / SWIFTEC FULL CRC
TRANSLATE DAMOS ENG
COUNTER FIX - VAG EDC16, EDC17
ORYGINAL FILES DATA BASE
START/STOP ON/OFF
Apsik (23rd June, 2018)
Sorry for late report but the good thing is that your solution worked just fine.
Thank you
please disable the egr from my file too
Here it is.
EGR OFF
fil1234 (20th November, 2018)
Hi. can remove for my egr ? fault 17811 P14035-008
others nox and lambda sensor P2270-001, P1033-002
Hi, need EGR Off Golf 5 03C906056AJ
tanks
filomenorocha (2nd July, 2019), klukasz2215 (24th February, 2020)
Hi, the file is not ok
can't write file, give error
I try to write, but galleto say that the file is (unrecognized)
you can correct chechsum for me? tanks for all
Hi, All,
could anybody please remove p0400 and p1070?
