Results 1 to 11 of 11
    Jul 2016
    Česká Lípa
    Default Skoda Superb 2.0 EDC17 DPF OFF
    Hello, I have a superbe 2.0 EDC17 DPF OFF, the problem is that after disabling the Volta the car still throws into the emergency mode. When I delete the service in the menu the car goes to full power, can someone please help me? DTC 0 errors.
    May 2017
    Turkey
    [QUOTE=dragocz;3313378]Hello, I have a superbe 2.0 EDC17 DPF OFF, the problem is that after disabling the Volta the car still throws into the emergency mode. When I delete the service in the menu the car goes to full power, can someone please help me? DTC 0 errors. [/QUOTE
    Empty the DPF can physically, erase all DTC stored in the ECU. Reset the DPF ash % value with tester (if possible) or use the "Replace DPF" option Make sure all sensors related to the DPF are connected and are electrically OK...
    Youre edc17cp14 dpf off here.
    Please test and report.
    Pass in pm.
    Dont forget click to thanks!!
    Genuine 'WinOLS,MagPro2X17 Master, VagCom-Vcds, Vag Can Pro-Vcp'
    And 'Kess-Ktag' Red Pbc Ecu Clone User.
    Professional Car Remapper And Ecu Calibration Expert From TURKEY
    Jul 2016
    Česká Lípa
    Please pass?
    pike's Avatar
    Sep 2013
    Has long existed DPF off solution with disconnect particulate filter sensors.
    May 2017
    Turkey
    Quote Originally Posted by dragocz View Post
    Please pass?
    I did sent you pass? check ur inbox please
    Jul 2016
    Česká Lípa
    Thank you, my password. The car is still in safe mode, it votes 0 errors, we think it still did the DPF:
    pike's Avatar
    Sep 2013
    Post here original file.
    Jul 2016
    Česká Lípa
    I dont have ori... :/
    Jul 2016
    Česká Lípa
    Here ori from internet.
    pike's Avatar
    Sep 2013
    Arrow Skoda Superb 2.0 EDC17CP14 DPF OFF
    I restored your file and made DPF off.
  11. The Following 2 Users Say Thank You to pike For This Useful Post:
    AVDigitale (28th June, 2018), dragocz (28th June, 2018)
  12. #11
    Jul 2016
    Česká Lípa
    Thank U! I go test.
