problem dpfoff 406 136 EDC15C2
Results 1 to 2 of 2
    Jan 2016
    47
    Downloads
    Uploads
    Default problem dpfoff 406 136 EDC15C2
    2.5.0.0
    I have dpfoff my car 406 136.
    So, I have more trouble fap clogged against since yesterday I saw the fap that turns on.
    error code in the engine calculator edc15C2:
    permanent defect: minimum level signal additive
    Can check if the defaper file is correct, please?
    At the bsi level, I disabled the additive calculator and the fap absent.
    AVDigitale's Avatar
    Apr 2017
    Every Where
    152
    Downloads
    7
    Uploads
    here is your file dpf off no cks pass in PM!
    in your file no dpf off
    Proffesional ECU Tuning
    DPF_EGR_ADBLUE_FLAPS_DTC
    Immo off MED/EDC17
    SKYPE: no skype !!!
    Don't ask for free files!
  3. The Following User Says Thank You to AVDigitale For This Useful Post:
    khassani (28th June, 2018)
