Results 1 to 14 of 14
    Apr 2016
    Default EDC16C34 Glow plug
    Anyone is abble to disable the glow plug error in this file?
    It's a Focus 1.6 TDCI and car is in limp mod, for now i need to fix it this way to move the car.
    Thanks in avdance,
    BR.
    Michaell
    Sep 2016
    upload dtc
    FILE SERVICE
    Apr 2016
    It’s P0380
    Sep 2016
    write and test
    FILE SERVICE
  5. The Following User Says Thank You to voltechcar For This Useful Post:
    SpecZ (28th June, 2018)
    Apr 2016
    For what i've read don't really know if the DTC removal will be enough.
    Hope so.
    maajkii's Avatar
    Mar 2017
    Poland - Sława ( Lubuskie )
    Quote Originally Posted by SpecZ View Post
    Hope so.
    Yes, DTC + Limp function from this is enough.
    Wysłane z iPhone za pomocą Tapatalk
    DSG TUNING
    File Service
    Jun 2012
    Did you solved?
    Apr 2016
    Quote Originally Posted by cawadany View Post
    Did you solved?
    Yes i did.
    P0380 off + glow plug monitoring off worked just fine.
  10. The Following User Says Thank You to SpecZ For This Useful Post:
    cawadany (29th June, 2018)
  11. #9
    ivanmihov's Avatar
    Nov 2016
    Europe
    in damos for edc16c34 is glow plug monitoring called "" Tester demand monitoring enable mask for glow relay "" or is "" Tester demand monitoring for glow control lamp ""
  12. #10
    Sep 2016
    yeah but you edit switch and this not work....tested.
    FILE SERVICE
  13. #11
    ivanmihov's Avatar
    Nov 2016
    Europe
    so switch + dtc off is needed
  14. #12
    Sep 2016
    not work, car have limp mode....
    FILE SERVICE
  15. #13
    Apr 2016
    Quote Originally Posted by ivanmihov View Post
    You have one more, i disable 3 switches.
    This was only to take the car out from a remote place, worked good but it's already in shop to install new plugs.
  16. #14
    ivanmihov's Avatar
    Nov 2016
    Europe
    is the third switch ""Switch for glow relay feedback diagnose "" ???
