Results 1 to 4 of 4
    dimitar's Avatar
    Default renault scenic edc16c36 egr dpf
    Does anyone have tested splution for this ecu
    edc16c36 0281 013 907
    50w Soldering Iron
    Chisel
    Sometimes Hammer
    johak's Avatar
    this should work
  3. The Following User Says Thank You to johak For This Useful Post:
    dimitar (30th June, 2018)
    dimitar's Avatar
    Doesnt work dpf reseted to 0
    No check light but after 2 min no power
    All sensors conected
    Previously there was fault df953
    50w Soldering Iron
    Chisel
    Sometimes Hammer
    dimitar's Avatar
    Johak your files works ok
    50w Soldering Iron
    Chisel
    Sometimes Hammer
  6. The Following User Says Thank You to dimitar For This Useful Post:
    johak (1st July, 2018)
