Test and report.
Dont forget click thanks!
Pass in pm
Test and report.
Pass in pm
Genuine 'WinOLS,MagPro2X17 Master, VagCom-Vcds, Vag Can Pro-Vcp'
And 'Kess-Ktag' Red Pbc Ecu Clone User.
Professional Car Remapper And Ecu Calibration Expert From TURKEY
dzevad (4th July, 2018)
Thanks to friend ilkertdi for help
After switching on the ignition, the fuel metering at the high pressure pump is switched on and extinguished unstable
CONTACT PM FOR A SOLUTION
Maybe someone else has a solution
here you have dpf off disconnect dpf sensors
calculate checksum before write pass in PM!
Proffesional ECU & TCU Tuning
Petrol and Diesel Engines
File Service
dzevad (5th July, 2018)
yet without a solution
software problem
this is my solution, you must disconnect first and next temp sensor and differential pressure sensor from dpf , if you not disconnect solution not work.
FILE SERVICE
dzevad (4th August, 2018)
