Page 1 of 3 123 LastLast
Results 1 to 15 of 32
    Jun 2018
    Default ford cmax 2004 1,6TDCi - PATS code 23, no outcode
    Ford focus cmax 2004
    1,6TDCi 3m5a-12a650-JF (Updated to JH ?? )
    0281011263
    7KTF
    Hi, i`ve a problem with mu mother`s in law car, won`t start. PATS code 23.
    I`ve resolder the IC, checked wiring, and still can`t initialize IC to PCM via IDS . There is no outcode stored in the PCM.
    I`ve connected PCM to Elmconfig on desk to eliminate wire problems, but when i try to write firmware there is error erasing memory and no go, also IDS can`t perform intital modul programming.
    two keys were added to IC with no problem but cant synich IC-PCM
    my electic told me to go to FORD AS but they told to bu new PCM wchich price is eqal to new car so i`m trying to fix this problem by myself and any help would be appreciated.
    Conected PCM via BDM100 and here is what i`ve got:
    kiszka's Avatar
    Aug 2009
    Reality of life :
    1:Never argue with an idiot, he will drag you down to his level and beat you with experience
    2:It’s hard to argue with a genius. It’s impossible to argue with an idiot
    3:Jealousy is a sign of inferiority
    4:Everyone lies
    How much rubbish you leave behind, so much rubbish someone will have to read, or maybe you yourself
    If you like to read garbage, don't slow down, just speed up
    Jun 2018
    IC dump via carprog
    kiszka's Avatar
    Aug 2009
    Reality of life :
    4:Everyone lies
    Jun 2018
    unfortunatly the same thing with new eeprom.no start, ID mismatch, no outcode.
    Mar 2017
    France
    hi
    with forscan you can do it by obd
    regards
    Jun 2018
    Quote Originally Posted by omarino View Post
    hi
    regards
    You mean synchro ? Tried it using Vscan V3 STN1170, no luck. "Module returned false outcode". Same with IDS. Also i cant clear memory when trying to write firmware in ElmConfig, programable module instalatian in IDS ( error 0-0x22 851082 couldn`t find what it means). Tried with another IC, PCM - same thing. In another car which works (my brother has the same model) stil car wan`t start.
    I`m trying to convince my brother to let me open his PCM and read full ecu dump and IC. then i will onlu reprogram key and hope the car will start, but he is affraid of his car being immobilized too
  8. The Following User Says Thank You to bolg For This Useful Post:
    kiszka (6th July, 2018)
  9. #8
    kiszka's Avatar
    Aug 2009
    Reality of life :
    4:Everyone lies
  10. The Following User Says Thank You to kiszka For This Useful Post:
    bolg (6th July, 2018)
  11. #9
    Jun 2018
    car is starting without any problem thx kiszka
  12. The Following User Says Thank You to bolg For This Useful Post:
    kiszka (7th July, 2018)
  13. #10
    Dec 2012
    hello i have the some problem how you resolve it?you did synchro with forscan?thanks
  14. #11
    gege974's Avatar
    Oct 2018
    réunion island
    if it does not work forscan ..
    post your ecu and dash please?
    Small circumstances produce great events : 02.47-tranquillité:
  15. #12
    Dec 2012
    Thanks for answear i try also to synchro with ford all in one but not working either.<br>the dump are full dump by carprog.
  16. #13
    gege974's Avatar
    Oct 2018
    réunion island
    what are your engine fault codes?
  17. The Following User Says Thank You to gege974 For This Useful Post:
    nbn (24th October, 2018)
  18. #14
    kiszka's Avatar
    Aug 2009
    Reality of life :
    4:Everyone lies
  19. The Following 2 Users Say Thank You to kiszka For This Useful Post:
    gege974 (24th October, 2018), nbn (24th October, 2018)
  20. #15
    Dec 2012
    hello my engine fault code in dash is B2139 and in ecu p1621.
