Results 1 to 8 of 8
    Default DCU 102 - Virgin dump
    Hello I have a problem with this ecu.
    Citroen Jumper III - 2.2 hdi - Engine 4HU.
    Ecu - DCU 102.
    The original ecu is damage - I have the fault P0603.
    I bought other ecu. But I need put virgin dump.
    I edit the ecu, Immo is OK but I need coding the inyector and the pump. But I canīt and the car donīt start.
    I need autosincro please.
    virgin file pass pm
  3. The Following User Says Thank You to yokazik For This Useful Post:
    InfoPerformance (7th July, 2018)
    thanks, but this file is necesary telecode the ecu and coding the inyector and the pump.
    I donīt know but I donīt coding the pump and the inyector and the car donīt star.
    You have file to autosincro??
    Please, Can I help me?? Thanks.
    Jun 2011
    belgrade,serbia
    visteon--dcu-102-virgen.zip here you are autosynchronization only have to code injectors
  8. The Following User Says Thank You to vladanr For This Useful Post:
    bmotor60 (17th November, 2019)
  9. #7
    DUPNICA BULGARIA
    Only immo code is reset no need coding
  10. The Following User Says Thank You to ilian_cho For This Useful Post:
    InfoPerformance (9th July, 2018)
  11. #8
    Quote Originally Posted by ilian_cho View Post
    I try and tell you.
