Results 1 to 12 of 12
    Default Fiat Ducato DPF off
    Hi Mates. I need dpf off in car like in title. MY 2014 2,3JTD 130 PS. More info in atached file.
    Sep 2016
    how much filling the filter you have just now?
    FILE SERVICE
    90 percent
    Sep 2016
    nad you know... reset dpf its immposible diagnostic tool? and to edit software you must have max 30%
    FILE SERVICE
    pike's Avatar
    Sep 2013
    Quote Originally Posted by voltechcar View Post
    Hi, I think that this maximum (30%) can be changed in file.
    macako6's Avatar
    Mar 2015
    As said by voltechcar, you must first reset DPF 0%, enter the file I send you, then everything will be fine.
  7. The Following 2 Users Say Thank You to macako6 For This Useful Post:
    NORSHAN (8th July, 2018), wronapl (8th July, 2018)
    Ok, i do this. Can u send me pass?
    Sep 2016
    in this ecu you must reset only a file and in eep not flash.....
    FILE SERVICE
  10. #9
    I have FiCOm, before write flash reset dpf in eeprom.
  11. #10
    macako6's Avatar
    Mar 2015
    Always do the procedure dpf replacement and reset parameters with ori file. then load DPF OFF file.
  12. #11
    Sep 2016
    more than 70% not reset any tool in 8f3.....
    FILE SERVICE
  13. The Following User Says Thank You to voltechcar For This Useful Post:
    macako6 (8th July, 2018)
  14. #12
    mihaiservice's Avatar
    http://www.quick-tuning.com
    Hello
    for all kind of MJD8.xx are switch in file to reset ash level also you can set ash manualy to 0% or more !
    Full WinOLS user
    Custom ENG/GER OLS file for ​ Tune /DPF / SCR / EGR / TVA / VSA / DTC and more...
  15. The Following 2 Users Say Thank You to mihaiservice For This Useful Post:
    pike (9th July, 2018), wronapl (10th July, 2018)
