file can not be downloaded
NORSHAN (8th July, 2018)
uploaded again
No problem with download.
reset dpf soot and oil service pass in PM!
Proffesional ECU & TCU Tuning
Petrol and Diesel Engines
File Service
Here's your DPF OFF Punto
first you have to reset DPF 0%
Always do the procedure dpf replacement and reset parameters with ori file. then load this
so thanks friend all soultion didnt work rpm 3000 only dtc found p1564 all dpf sensor disconncted
Hi, your SW number refers to the Fiat Doblo, did you confuse anything?
NORSHAN (9th July, 2018)
NORSHAN (10th July, 2018)
any body has trustrd soultion
dtc p1564
p2002
p1302
p2452
p1206
and rpm cant excced over 4000 rpm
Try this file
same pass
so thankh freinds all soultion above didnt work car in limpe home mode rpm 3000
any trusted and tested soultion please
Write this
Pass PM
NORSHAN (11th July, 2018)
