Page 11 of 44 FirstFirst ... 67891011121314151621 ... LastLast
Results 151 to 165 of 660
Hybrid View
    and my device is X300 DP full.
    I searched the device to fined log files.
    only found home\device\app\and then log files.{not orgnized}
    so I copied one file to google translator, to know what is it.
    result is vietnames lang and wrong translating.
    so , can you explain , how to search and find log files .
    Apr 2018
    Quote Originally Posted by m-o-y View Post
    This needs the 5th Toyota Simulated Smart Key, which is in the developing now
    Moderator
    PremierD's Avatar
    Jun 2009
    Bet she does not know ..( being in the sales dept..) and has to ask ........
    Jan 2017
    USA ����
    It's inside the DP program in the tablet
    thanks ,
    still need to know How to get log files
    and is it right ?
    local/device\app\etc.
    Apr 2018
    thanks ,
    and is it right ?
    Pls check the attached instruction.
    Log file will get to the background system and can be checked with your SN number.
    Jul 2018
    Key Master DP Standard version.
    Cannot find the "ODOMETER Correction" option anywhere?! Did anyone have similar issue?
    Please help me
    Apr 2018
    Quote Originally Posted by Friends4eva View Post
    Please help me
    Pls send the pictures of device menu
    sorry , I told you I checked in
    Home\DP\s.n folder\log
    It is many log files.
    and it is not in English language. and not range by time and date.
    so my question , is how can I find my request file.
    thanks anyway
    Apr 2018
    thanks anyway
    If you don't know which one, pls delete all files now. Test again to get the new log file.
    Jan 2017
    USA ����
    Quote Originally Posted by SMP7 View Post
    dont listen to him
    http://www.digital-kaos.co.uk/forums...=1#post3280183
    go there do that
  13. The Following User Says Thank You to sleepyrz For This Useful Post:
    hcip (28th August, 2018)
  14. #13
    auto techniek's Avatar
    Mar 2017
    SMP7@ How to know if tool full version with C package?
    I ve ordered one and need to check.
  15. #14
    Apr 2018
    Quote Originally Posted by auto techniek View Post
    X300 DP Plus C Configuration?
    • Includes Below:
      Immobilizer+Mileage correction+Diagnosis+Special function (Oil rest +ABS+Battery matching+ECU programming+EPB+Throttle programming+Airbag rest+TPMS+Steering angle rest+OBDII+DPF+Injector code+Supension matching+Gear learning+CVT learning+EEPROM+Key renewing+ECU cloning)Adapter(P001 programmer+C001 circuit board+C002 circuit board+W001 data cable+W002 data cable+W003 data cable+Toyota smarkt key Emulator)+others(Ignition coil+Remote tester)
  16. #15
    Jan 2017
    USA ����
    click this attachment
    you need to go into the DP program
    NOT INTO THE FILES
    go to the report center in the DP program
    select all of the files and send them all
    then contact them through skype or whatsapp and give them your serial so they can retrieve your log files from the server and look into it
  17. The Following User Says Thank You to sleepyrz For This Useful Post:
