Page 40 of 44 FirstFirst ... 3035363738394041424344 LastLast
Results 586 to 600 of 658
  1. #586
    Apr 2016
    when x300dp writes mileage to chryslers 2014+ changes also working hour clock?
  2. #587
    Suzuki Baleno 2018 smart key AKL - OK
  3. #588
    ...where was Columbus
    no, use other tool , or by your hands (by eeprom)
  4. #589
    Alekso's Avatar
    Did somebody have succes to read precoding and program blade key for Fiat Tipo 2016y. with new megamos id88 transponder.
    ...or any other Fiat with megamos 88. Im thinking about blade key.
    Thank you
  5. #590
    Aug 2019
    Does anybody have obdstar vagpro?
  6. #591
    Supas's Avatar
    Jun 2020
    With x300 dp plus with active license ....
    Dashboard VW VDO UDS with NEC + 24c64 from year 2013 onwards I couldn't do any AKL and neither ADD key.
    I also tried the brasil pack and nothing ..
    The result is always the same...
    -Failure Login
    -2711 Check Failed
    -Security verification Failed
    In the Fiat Palio INMO system with the Marelli dashboard with 95160, when reading the key pin, it corrupts km and sets it to 999999 and then from the instrument calibration menu, it does not modify the km
  7. #592
    centrohifi's Avatar
    Apr 2011
    From Italy .......
    Quote Originally Posted by Alekso View Post
    Thank you
    x300 PAD2 was successful, even videos on youtube!
    ..Ecu Repair ... Steering Wheel Repair ... Dash Repair ... AirBag Repair .... that Bad LiFe ...
  8. #593
    hi
    i have obdstar t300 pro here is serial number 100300136780 i forget to registered the device plz help and memrry card damage
  9. #594
    centrohifi's Avatar
    Apr 2011
    From Italy .......
    hello, I have a problem with programming key polo 2012 ID48, follow all the instructions and the video on youtube, but in my thing I can't generate the OEM key ...
    Use OBDStar X300Pad
  10. #595
    Jan 2014
    hi all
    OBSDTAR X300 PRO4 Key Master 5 Auto Key Programmer
    any one use this device
    any feadback
    read them !!!
  11. #596
    Aug 2013
    Hello. After updating the program, I have a problem with making a dealer key in the Audi A4L. Both times I got a "seek file failed" message. Before the upgrade, this was not a problem. Does anyone else have this? X300 DP plus.
  12. #597
    Sep 2019
    Anyone confirm if update 30.95 is released yet?
    Sent from my SM-A505FN using Tapatalk
  13. #598
    May 2020
    Obdstar x300 pro4
    Ford galaxy y2014 with 4d 80bit, failed to program a key. It does something and when it should program a key a message pops (security verification failed). I can't clone that transponder either with any cloning tools.
  14. #599
    looks like they got the other emulator keys working for Toyota
  15. #600
    Jan 2021
    I purchased a H105 and H108
    Its pulled the pin codes from 2 Peugeots so far but could not touch a i30 2008 Hyundai with a 46 transponder.
