Page 41 of 44 FirstFirst ... 31363738394041424344 LastLast
Results 601 to 615 of 658
  1. #601
    now this is the 6 post i see that you ask the same question.
    is it no time to pass the job to a other?
  2. The Following 2 Users Say Thank You to vageric For This Useful Post:
    PremierD (2nd February, 2021), rtbdiagnostic (18th February, 2021)
  3. #602
    Sep 2016
    I need help add remote key pcf 7946 for Iveco Daily 2015. There are 2 types .Typ1-read pin code.Type2 read eeprom 95c640. Which to choose? Need FCA 12+8 Universal Adapter?
  4. #603
    Feb 2019
    Chester UK
    I have OBDSar DP300. When I try to use it, I can select Immo, then brand and then I can sometimes get further till eeventually it goes back to start menu. Each time I try it crashes at different pages/times.
    Has anyone had this problem?
    I would like to update my update subscription but I think it's better to solve this problem.
    Any ideas?
    TIA
  5. #604
    vialli's Avatar
    Aug 2018
    Romania
    Quote Originally Posted by AA247 View Post
    Any ideas?
    TIA
    If your device's update service was expired, please don't have following actions.
    1.To click "Upgrade"
    2.To reset the device.
    3.To clear cache.
    Otherwise, this message might occurred "Unfortunately, DiagProgram has stopped". Then the DiagProgram will not work unless you buy the update service to update it.
  6. #605
    Dec 2020
    Hi, someone knows if it's possible to read PSA Bsi on bench with Obdstar x300dp? I've already tried on a Valeo Bsi (K-Line) with no success, by the way i've used the pinout from IO Terminal. I've also seen videos on their channel where they read bsi on bench but with a complete bench testing cable..
  7. #606
    Oct 2018
    help please!!!
    my obdstar300 dp plus stop working today, at first show a message on the screen "unfortunately, the process com.android.phone has stopped" after i press OK give me another message "unfortunately system UI stop working" and and doesn't let get into de software... doesn't let me go move forward to the mail menu (desktop), i buy this tool 5 months ago so i'm still good on my subscription, i get this tool from the the official websiteobdstarstore.com and been asking for technical support and NO ANSWERS ... if anyone had a solution, or run into this problem before and got a way out, please any help would be great
    (video)
    https://vimeo.com/514841818?ref=em-share
  8. #607
    Mar 2021
    spain
    In bank you can not, by obd.
  9. #608
    Mar 2018
    Estonia
    Deleted post
  10. #609
    figani's Avatar
    Feb 2018
    47 45 52 4D 41 4E 59
    Someone of you tried AKL function on Smart 453 / Renault Twingo..?
  11. #610
    whiskeyman's Avatar
    Dec 2010
    where men are men and women eat their babies
    looks like toyota function too generate smart key
    with simulated key from dump not working
    after new update
    v32.20
  12. #611
    Jan 2012
    Hi, I have obdstar key master dp plus (green color full touch pad) my subscription was expired from months , now it give me attached error, some one face this issue before ? How to solve this ? I contact supplier, they told me to send back main unit!!
    Best Regards
  13. #612
    whiskeyman's Avatar
    Dec 2010
  14. The Following User Says Thank You to whiskeyman For This Useful Post:
    Niaz (23rd August, 2021)
  15. #613
    Jan 2012
    Thanks mate for your input , i have this product " http://www.obdstar.com/Products_266.html " it not have built-in tf/sd card , but i put blank card and copy that bin file to card & restart but nothing happened ! same issue on every diag option .
    Best Regards
  16. #614
    lion0304's Avatar
    Oct 2014
    Toyota 32.51 is online. If like me you've got 32.20, you can update again.
  17. #615
    whiskeyman's Avatar
    Dec 2010
    Quote Originally Posted by lion0304 View Post
    thanks will try again and see if it recognise files now
