yes yes ..... I know well that a tool is never enough ... I have several tools for engine ecu and mcu programmers but on the keys I'm starting now ... is dropped as updates ......
[SIZE=3][I][FONT=impact][COLOR=#ffd700]PUSH THANKS AND REP IF I HELPED YOU !!!!!!
Howzit
Need your advice any success with ODO Master or perhaps the OBDProg M500 on the Renaults kwid Clio IV Captur etc on blocking sync with ABS pump
Also on the newer Ford Rangers 2019 onwards with Renesas prcessor any luck via obd with Odo Master perhaps
Your feedback much appreciated
'If I helped, please click Thanks +Reputation.. !'
Hi , mates !
Can ObdStar Key Master DP Plus adding key to CAS3++ IstaP from BMW E60 2007 , petrol . Is the downgrade by OBD safe ? I try another option from Eeprom dump from CAS make a starting key , ObdStar programming a new key , but no generate new dump for CAS module ... If anyone has experience with this tool and BMW CAS3+ crypto eeprom , please share , thank you !!
hi
Anyone try new VOLVO update sw for X300dp?
I have 2007 v40 with lost key
I read CEM both motorola MCU as per instruction and can get PIN but when go to V40/FOBIK/24 pin system I'm instructed to turn key to ON after that I can't get comms as Ignition not turned ON
how to get ignition ON when I don't have working key??
Friends what about renault kadjar after 2016 any succes with card programing ?
holbi1 (8th November, 2022), rtbdiagnostic (31st October, 2022)
Yes, you are warned that in order to calculate the security code, the keys will be deleted from the memory.
That's exactly how it is after the flash is read, the car is dead, the key no longer works.
I read the flash a second time and compared them at home, the second one had a small part modified with FF, that is, something was really deleted during the first flash reading.
For dealer key and programming I used the first reading and I was successful
Today I had a 2015 Trafic 3 with all the keys lost.
I was successful in programming a new key.
I have attached a picture with the warning you get if you take the risk of programming a new key, I apologize for the modest quality of the picture.
My message is that a new key can be made in the AKL situation with this programming tool.
That is if you are brave enough to try.
holbi1 (13th December, 2022)
buy x 300 key master work ok
anyone got obdstar x300dp boot files for repair of tablet via sd card
What exactly you need to repair? I've got only some APK files for the software.
djollie (24th February, 2023)
tablet freezes on startup at obdstar logo...apparently requires boot files on sd card to repair.
If you ask me it is not so "apparent". I would not exclude a hardware problem too.
Your only chance is to contact OBDStar support. Good luck!
