Page 43 of 44 FirstFirst ... 3338394041424344 LastLast
Results 631 to 645 of 658
  1. #631
    hcip's Avatar
    Dec 2009
    From the heaven of paradise in the middle of happiness|hobby:__Bedtime| Sex:Female|Status:Not_Virgin
    Quote Originally Posted by saslocksmiths View Post
    Everything has its place obdstar is a good tool it has got me out of trouble a few times when nothing else work, but for Mercedes it's not good butt its is very good on Asian vehicles I guess it all depends on what you want to use it for and keep in mind that not one tools does everything I have advanced diagnostics I have smart Pro I have sbb I have nanocom I have vvdi key tool Plus I have obdstar I have Avdi original tango tmpro Orange five the list goes on how I wish I could buy one till that did everything it would make so much more room in my vehicle
    Nothing is one shot , Big Shot.
    all tools have advantage and dis advantage.
    Its like a simple that when you buy an air Rifle, you can not shot an elephant......
    Stupidity is not a disease, because there are no existing hospitals for Idiots!
  2. #632
    joker01's Avatar
    Jan 2018
    yes yes ..... I know well that a tool is never enough ... I have several tools for engine ecu and mcu programmers but on the keys I'm starting now ... is dropped as updates ......
    [SIZE=3][I][FONT=impact][COLOR=#ffd700]PUSH THANKS AND REP IF I HELPED YOU !!!!!!
  3. #633
    rtbdiagnostic's Avatar
    May 2015
    My Tool Room
    Quote Originally Posted by hcip View Post
    Howzit
    Need your advice any success with ODO Master or perhaps the OBDProg M500 on the Renaults kwid Clio IV Captur etc on blocking sync with ABS pump
    Also on the newer Ford Rangers 2019 onwards with Renesas prcessor any luck via obd with Odo Master perhaps
    Your feedback much appreciated
    'If I helped, please click Thanks +Reputation.. !'
  4. #634
    Nov 2009
    Bulgaria
    Hi , mates !
    Can ObdStar Key Master DP Plus adding key to CAS3++ IstaP from BMW E60 2007 , petrol . Is the downgrade by OBD safe ? I try another option from Eeprom dump from CAS make a starting key , ObdStar programming a new key , but no generate new dump for CAS module ... If anyone has experience with this tool and BMW CAS3+ crypto eeprom , please share , thank you !!
  5. #635
    Jan 2010
    EU
    hi
    Anyone try new VOLVO update sw for X300dp?
    I have 2007 v40 with lost key
    I read CEM both motorola MCU as per instruction and can get PIN but when go to V40/FOBIK/24 pin system I'm instructed to turn key to ON after that I can't get comms as Ignition not turned ON
    how to get ignition ON when I don't have working key??
  6. #636
    Sep 2013
    Friends what about renault kadjar after 2016 any succes with card programing ?
  7. #637
    vialli's Avatar
    Aug 2018
    Romania
    Quote Originally Posted by holbi1 View Post
    I was successful in adding a new Chinese card to a 2019 Kadjar a month ago
  8. The Following 2 Users Say Thank You to vialli For This Useful Post:
    holbi1 (8th November, 2022), rtbdiagnostic (31st October, 2022)
  9. #638
    Sep 2013
    Quote Originally Posted by vialli View Post
    Viali it was info about risk damadge when you choose read flash ?
  10. #639
    vialli's Avatar
    Aug 2018
    Romania
    Yes, you are warned that in order to calculate the security code, the keys will be deleted from the memory.
    That's exactly how it is after the flash is read, the car is dead, the key no longer works.
    I read the flash a second time and compared them at home, the second one had a small part modified with FF, that is, something was really deleted during the first flash reading.
    For dealer key and programming I used the first reading and I was successful
  11. #640
    vialli's Avatar
    Aug 2018
    Romania
    Today I had a 2015 Trafic 3 with all the keys lost.
    I was successful in programming a new key.
    I have attached a picture with the warning you get if you take the risk of programming a new key, I apologize for the modest quality of the picture.
    My message is that a new key can be made in the AKL situation with this programming tool.
    That is if you are brave enough to try.
  12. The Following User Says Thank You to vialli For This Useful Post:
    holbi1 (13th December, 2022)
  13. #641
    Jun 2016
    Mexico
    buy x 300 key master work ok
  14. #642
    anyone got obdstar x300dp boot files for repair of tablet via sd card
  15. #643
    Feb 2014
    What exactly you need to repair? I've got only some APK files for the software.
  16. The Following User Says Thank You to autoTkey For This Useful Post:
    djollie (24th February, 2023)
  17. #644
    tablet freezes on startup at obdstar logo...apparently requires boot files on sd card to repair.
  18. #645
    Feb 2014
    If you ask me it is not so "apparent". I would not exclude a hardware problem too.
    Your only chance is to contact OBDStar support. Good luck!
  19. The Following User Says Thank You to autoTkey For This Useful Post:
