Page 14 of 44 FirstFirst ... 491011121314151617181924 ... LastLast
Results 196 to 210 of 660
  1. #196
    Jan 2017
    USA ����
    Yes exact same problem as above video
  2. #197
    Apr 2018
    @sleepyrz @m-o-y @finakeys
    Where are you from? to contact the customer service accordingly
  3. #198
    Jan 2017
    USA ����
    Quote Originally Posted by SMP7 View Post
    usa florida
    UHS is my supplier
  4. #199
    Dec 2017
    UK - Got it in tradelocks. Surely this has something to do with a software update and not hardware?
  5. #200
    Jun 2010
    yes , I think it is sotrware problem.
    and I am from Sudan.
  6. #201
    Jan 2017
    USA ����
    Quote Originally Posted by finakeys View Post
    probably hardware
    if it was software it would be all the tablets
    we just probably got a few bad screens that failed early
  7. #202
    rob h's Avatar
    May 2011
    The box, storing the set, is a bit small.
    Some pressure, from a bad packed cable or connector could ruin it!
  8. #203
    Jul 2018
    DP Key Master pad-
    Will the Smart key emulator works on Prius 20 ( Gen II) , Have any one tried? Does it require internet connection?
    TIA
  9. #204
    Jan 2017
    USA ����
    Does anyone else hear rattles inside?
    It sounds like a screw or two came out inside and are bouncing around
    https://youtu.be/dhnvfKXhokw
  10. The Following 2 Users Say Thank You to sleepyrz For This Useful Post:
    Jobeso66 (14th November, 2019), rob h (5th October, 2018)
  11. #205
    Feb 2012
    x300dp full add key RANG ROVER SPORT 2015 FAIL
    Job dane by AVDI ORI
  12. The Following User Says Thank You to inaro For This Useful Post:
    chcp (6th October, 2018)
  13. #206
    Dec 2017
    No rattles no... Do you know how to flip the screen like the vid?
  14. #207
    Jan 2017
    USA ����
    yes that is my video
    put buttons on left side of screen
    go to settings and then turn off autorotate and lock display to portait mode
    voila
  15. The Following User Says Thank You to sleepyrz For This Useful Post:
    finakeys (6th October, 2018)
  16. #208
    Dec 2017
    was speaking to OBD star support. They are sending out a new screen which they say will remedy the problem... Can just about hit the enter button atm with about 20/30 aggressive taps... Cheers for the info... will come in useful in the meantime
  17. #209
    Jan 2017
    USA ����
    Realize the top of the screen will now not work and you may have to go into settings and turn it back on again
    And back and forth
  18. #210
    Dec 2017
    yea... i kno... the x300 has been a backup to the smart pro... so far the x300 is winning 60/40... which shouldnt really be the case
