Suzuki Baleno 2018 smart key AKL - OK
no, use other tool , or by your hands (by eeprom)
Hello,
Did somebody have succes to read precoding and program blade key for Fiat Tipo 2016y. with new megamos id88 transponder.
...or any other Fiat with megamos 88. Im thinking about blade key.
Thank you
Does anybody have obdstar vagpro?
With x300 dp plus with active license ....
Dashboard VW VDO UDS with NEC + 24c64 from year 2013 onwards I couldn't do any AKL and neither ADD key.
I also tried the brasil pack and nothing ..
The result is always the same...
-Failure Login
-2711 Check Failed
-Security verification Failed
In the Fiat Palio INMO system with the Marelli dashboard with 95160, when reading the key pin, it corrupts km and sets it to 999999 and then from the instrument calibration menu, it does not modify the km
hi
i have obdstar t300 pro here is serial number 100300136780 i forget to registered the device plz help and memrry card damage
hello, I have a problem with programming key polo 2012 ID48, follow all the instructions and the video on youtube, but in my thing I can't generate the OEM key ...
Use OBDStar X300Pad
..Ecu Repair ... Steering Wheel Repair ... Dash Repair ... AirBag Repair .... that Bad LiFe ...
hi all
OBSDTAR X300 PRO4 Key Master 5 Auto Key Programmer
any one use this device
any feadback
read them !!!
Hello. After updating the program, I have a problem with making a dealer key in the Audi A4L. Both times I got a "seek file failed" message. Before the upgrade, this was not a problem. Does anyone else have this? X300 DP plus.
Anyone confirm if update 30.95 is released yet?
Sent from my SM-A505FN using Tapatalk
Obdstar x300 pro4
Ford galaxy y2014 with 4d 80bit, failed to program a key. It does something and when it should program a key a message pops (security verification failed). I can't clone that transponder either with any cloning tools.
looks like they got the other emulator keys working for Toyota
I purchased a H105 and H108
Its pulled the pin codes from 2 Peugeots so far but could not touch a i30 2008 Hyundai with a 46 transponder.
