Results 1 to 5 of 5
    drewdom's Avatar
    Aug 2010
    58?59'13.1"N 6?11'19.4"E
    Default Volvo V50 Sid 803A dpf help
    Hi Friends.I need help with dpf off in this file ecu trhows also some errors from addtive device.
    Please dear members push the button if my work was helpfull!
    And reputation button(star)
    Mar 2017
    here is your dpfoff mate
    pass in the PM
  3. The Following User Says Thank You to ZAHEER For This Useful Post:
    drewdom (10th July, 2018)
    drewdom's Avatar
    Aug 2010
    Thank's this is same like ads dpf remover is this working solution?
    Mar 2017
    yes two days ago i did and worked
  6. The Following User Says Thank You to ZAHEER For This Useful Post:
    Flash must be read BDM ?. Is OBD reading enough?
    Is OBD reading enough?Is OBD reading enough?
