Both immo id....SKZ7Z0H4765435
rorig dash........02021
ecu orig...........02021
hello
i have skoda roomster 2008 with magnetti marreli ecu petrol 4HV
i try program key but not succes
can help me give component security correct
i thing my abritus clone not give corect data
10 FF E5 7 0 0 A5 component protection data and pin 2021 it-s good
how should I do that?any help is welcome i have lonsdor,x100pad2
I tried all the variants
I do not understand why I can not program it
thank you sandu I will try
Wrong put ,security time active 15-25 min.
Ignition on and wait .........
i try 30 min ignition on but not succes
for how long? wait until the key led no flashes?
serial dash 5J0920 810B
Hi, if you have vcds go to immobilizer 25 not to dash 17, and all will done, maybe your diagnostic tools not accepting.
rdu04 (13th July, 2018)
i finally leave ingition on for 1 hour after can programming key thanks to all for help
Hi. We have same problem with skoda roomster 1.4 Benzin. Immo Chanel locked! Need wait 1 hour with IGn. On?
You have prepared ID48 T24 for skoda or normal ID48 Transponder learning?
skoda fabia 2008 all lost key
hello counter 5j0920 811 c pam 93c86 pin needed in advance, thank you very much vvdi prog 93c86.rar
pin code is 01711
