Results 1 to 2 of 2
    Feb 2018
    Mexico
    Default HELP Mitsubishi L200 2017 Change VIN in modules ECU and ETACS
    Hello, I am replacing the modules (ECU and ETACS) Mitsubishi L200 2017, the truck is already starting but I would like to change the VIN to
    MMBNL45K2HH082092
    ETACS memory eeprom 25320
    Eeprom memory ECU 95160
    Now try to change the VIN in both modules with the software "ETACS Decoder" but set DTC B1A28 (ECU authentication error), try to perform the special function "ENG Key Code & VIN Reg" with the scanner launch X431 Pro but you can not perform the function.
    Somebody could help me to change the VIN and the matching of the modules (ECU, ETACS) and if possible without removing the programmed key
    I attach the original files with which the truck starts
    regards
    MartiLer's Avatar
    Dec 2016
    try it......
  3. The Following User Says Thank You to MartiLer For This Useful Post:
    gandrade (9th August, 2018)
