Results 1 to 1 of 1
Thread: smart 800 cdi
    alonedark's Avatar
    Feb 2017
    Default smart 800 cdi
    smart diesel 450 with problem
    I have a problem with a Smart diesel. I try to put it front and do not start with nothing. common rail system is okay i have 360 rail pressure, the regulator of pressure of the rail is ok, crafsensor is ok i have 260-290 rpm . I do diagnosis and show no dtc , i found that no pulses injectors. can be posible remove Inmothe ecu to send pulse to inyector, ifi have some inyector bad show this ecu dtc?
    Can be posible the problem whith inmo in ecu, the keys works fine .
    thant you in advance
