028105242 ????? Give correct number.
Edc16c34 bricked by mpps
I need full bdm read. Ford focus 1.6tdci 2008 395209 028015242
I tried write another bdm file with ktag, without results.
Ktag can read bdm file from bricked ecu but filesize of bdm was 457kb and that bdm file what i tried to write was 462kb. Ktag writes back that file what was readed before.
Is there somekind encryption?
Bosch number: 0 281 015 242
Sw: 1037395209
Hi. If You need I have 0281015242 1037399617
Is that ktag bdm?
Ktag 66 plugin don't work because ktag doesn't recognize ecu. But still reads flash 2048kb eeprom 8kb and full file 457kb apparentaly it's somekind alientech crypted file.
457kb is backup file, no need write this.
If you want to recover ecu, put this 457kb file in a map, and put in this map eep + flash or mpc what you have (readed full) and ktag or ksuite will find on backup (457kb file) the eep + mpc or flash.
OR, you can write manually eep + flash/mpc, but if you write it manually, ktag don't make checksum. So this situation can be used if you write full ori file.
regards,
Sedat Garip
Chiptuning Remapping, file service, stage 1 & 2 dyno tested.
Diesel + petrol All cars
Manual Adblue dpf egr Opf tested working solutions
Belgium
With Kind Regards,
Don't forget hit thank button if i helped.
Try these one.
no pass
Hi everyone!
i need ktag bdm file 457 kb for this ecu 0281015242 1037399617
Please help.
