Results 1 to 8 of 8
    Feb 2017
    Venezuela
    Unhappy Eeprom 93c66 I cant programmer with Willem 4.5. Help!!!
    Hi, everyone. I have a Willem 4.5, I can read eeprom 93c66 16 bit , but when I want programming always say error.
    I probe with 2 eeprom, and with 3 immo off from Toyota Corolla, that I found in this forum.
    I read a lot but I cant find which is problem.
    Datasheet say pin 6 ORG must have VCC to program 16 bit, I jumper pin 6 with pin 8. No programming, ERROR.
    I know that dumps are OK because many people say that work fine.
    Please, I need write this eeprom.
    Thanks!!!!
    Mar 2013
    Europe
    When you habe Digiprog you can try it
    Dec 2015
    Friend try to use external 12v 1amp power adapter to write
  4. The Following User Says Thank You to aandroma For This Useful Post:
    dshimkute (29th July, 2018)
    brend's Avatar
    Oct 2015
    Same where
    Its very simpel work with this eeprom like 93Cxx.
    Look better contakt and dump size.
  6. The Following User Says Thank You to brend For This Useful Post:
    Feb 2017
    Venezuela
    Thanks for your answer. Can you explain better how do it this? Where I connect this 12v?
  8. #6
    Feb 2017
    Venezuela
    Thanks for your answer aandroma. Can you explain better how do it this? Where I connect this 12v?
    Eeprom is sold in adapter sop 8 -dip 8, solder are good, all pins have continuity with own leg. I can read but cant write, dump size are ok. When I check voltage, pin 8 have 5v when read or write, pin 6 have 5v, because I put to Vcc for 16 bit, pin 1 have 5v when write, pin 3 have 5v and when I click in Programmer Chip down to 0.19v, pin 4 have 0v and when I programmer chip up until 0.49v.
    I try to write 3 eeprom virgin, with differents dumps. With all dumps program say ERROR.
    What is wrong?
    Thanks guys for your help.
  9. #7
    rafal's Avatar
    UK - PL
    need help
    now my goal is to buy xp-005
    who will help?
  10. #8
    Feb 2017
    Venezuela
    Hi, someone can help?????
    Whats is wrong?
    LPT in Bios configured in epc.
