no possible by eeprom, you need abritus for this. you need to read eeprom from "gateway" then you can remove CP
http://www.digital-kaos.co.uk/forums...ighlight=mmi2g
i saw on this thread that people solved problem just by eprom.
by the way, i dont have abrites, just clone fvdi and i have tried with him but without success.
i see, thank's for the info. try to contact "pepina", he can help you
Corect name is'pipina'.
Can someone send eeprom file or help on some other way...?
I am willin’ to pay if is neccessary..
Hi, here it is. Should work. Report!
brodaty (5th November, 2020), Drdiag (2nd August, 2018), electroniquearts (27th February, 2019), jackie86 (2nd August, 2018)
man, you are the KING! this works
thank you very much..
Hi there, is someone kind enough to give me the password for the above file? regards
Hi, need CP OFF on MMI2G 4F0910613d eeprom 24c64
r420 (29th April, 2020)
auto12volts (18th February, 2019), r420 (29th April, 2020)
Can I have pw for this please?
Hi,mr Pipina i have problrm with MMI component protection,can you help,thanks.
Hi, i need remove cp from audi mmi 2g
4e0035729
inside 24c64
tanks for help
Hello. I wanted to ask for help in disabling cp mmi 2g 4e0035729
