Just flash ori.
Hi gays i need help
The problem is that it breaks turbos at 10 km oil pressure is good, all turbo roads are clean, but have a problem
The ecu is with remap.
I already wonder if the problem is not on the map, can anyone look at it and share opinion
Tanks
Just flash ori.
DSG TUNING
File Service
True, flash original and see if turbo last longer than 10km.
it would be good for the original but if it broke it again
so I ask you how the map is if or look for another problem
because it costs a lot of money and if it breaks it will be fifth turbos
so I ask you how it is a map
the turbine when it bursts breaks the whole cold part
Then i would suspect dust in oil filters on pipe which feeds turbo, seems lack of lubricant.
Hey
This doesn't sound problem in the file
Anyway the maps look pasted from other file
Here is a safe file, you can try it
tugishrugish (6th August, 2018)
Ok thanks i will try it but will you be able to attach it again because i can not download it
when I'm not logged on to the forum and try to download something then it does not allow me to download it unknowingly why tnx
Have you any diagnostic adapter, to check live data ? it would be first thing to do after you write ori file
Hello I found the problem does not unload the turbine properly, so it breaks with a new valve n75 for now there is not problem
now I will put the old chip that with it the car was crazy and I will check the values
thanks to everyone who has responded
