Results 1 to 15 of 26
Thread: Nissan LCN EU
    Oct 2015
    Default Nissan LCN EU
    Hello.Im searching for pinout+projecton main board for Nissan LCN EU(OMAP5948)JTAG link for Segger Jlink interface.
    Jul 2013
    try this
    good luck
  3. The Following 8 Users Say Thank You to petronijul For This Useful Post:
    bonux (1st March, 2023), credoline (25th March, 2019), irfa (2nd August, 2018), masterskay62 (2nd August, 2018), patifon (2nd August, 2018), smoggy (2nd August, 2018), Thinner (2nd August, 2018), tom222 (8th December, 2020)
    Oct 2015
    To reset the counter, I erased the 265,266 sector, the device no longer works. What should I do?
    Apr 2013
    Nessebar - on the Black Sea
    Quote Originally Posted by patifon View Post
    You should wait longer time for reboot. After erasing those two sectors unit doesn't start as usual, it needs more time - about 2-3 minutes.
    Hope you didn't mess with the sectors and did a back up ...
    wbr
  6. The Following 2 Users Say Thank You to prodan For This Useful Post:
    rsologubov (12th February, 2021), Thinner (2nd August, 2018)
    Oct 2015
    I considered this sector(265,266).
  8. #6
    Oct 2015
    I try to sew back, there is an error(J-Flash V6.32i Error
    Programming failed @ address 0x02120000 (program 1 over 0)
    Program failed
    Failed to program target
  9. #7
    Apr 2013
    Program failed
    set correct flash start address...
  10. The Following User Says Thank You to prodan For This Useful Post:
  11. #8
    Oct 2015
    265, 266 sector Start 2120000 End 215FFFF ???
  12. #9
    Aug 2015
    code is 8629. Do you have a full dump before erase?
    wbr
  13. The Following 4 Users Say Thank You to Thinner For This Useful Post:
    credoline (25th March, 2019), irfa (2nd August, 2018), patifon (2nd August, 2018), smoggy (2nd August, 2018)
  14. #10
    Apr 2013
    2A120000 - 2A15FFFF
  15. The Following User Says Thank You to prodan For This Useful Post:
  16. #11
    Oct 2015
    There is no complete dump, there is only 265,266 sector.
  17. #12
    Oct 2015
    Selected Data (0x2A120000 - 0x2A15FFFF) does not fit into selected flash sectors.
    Relocating it by -0x28000000 bytes would fix this problem.
    Do you want to relocate?
  18. #13
    Oct 2015
    Could not execute task.
    Selected Data (0x2120000 - 0x215FFFF) does not fit into selected flash sectors.
    Could not program target, no license
  19. #14
    Apr 2013
    set your project file ---- options -> project settings -> flash , set your flash base address as I wrote earlier!
    and when you load your data choose 0x2A120000 as a start address
  20. The Following User Says Thank You to prodan For This Useful Post:
  21. #15
    Oct 2015
    Thank you all, the device has stood up and has given the code request, the code is correct.
  22. The Following User Says Thank You to patifon For This Useful Post:
