Page 2 of 2 FirstFirst 12
Results 16 to 23 of 23
  1. #16
    Germany
    Yes, you can resolder with hot air also. Just buy a flux pen. Make some flux to the solder pads, put eeprom on pads, and make it hot. The eeprom will swim to the right position. Buy a good station, where you can set the temp. Otherwise your can overheat eeprom and pcb. Make training with some old pcb´s.
    Greets MR...
  2. The Following 2 Users Say Thank You to brobble For This Useful Post:
    jackieboy8 (20th August, 2018), Johnner (20th August, 2018)
  3. #17
    melbourne, australia
    the problem is the risk of corruption. if you lose the dump you are in a world of hurt. safer to desolder & only takes 5 minutes anyway
    personally, I always desolder, sometimes, once ive got the dump & will try to read in circuit so I know for next time
  4. #18
    Oct 2020
    Bulgaria
    Quote Originally Posted by cqae View Post
    Everyone says its safe to desolder, but i not found yet real case when in circuit programming is corupted something...
    I do many clusters (maybee 200-300) in last 3, 4 years, never desolder eeprom, just sop8 clip or pogo pin probe, and job done for 1 minute. Even my cheapest eep programmers read/write ok (i will never take the risk to heat/burn the chip with important for me data).
  5. #19
    Smart66's Avatar
    Dec 2020
    Anyone who tried read 93C86 without removing with Carprog?
  6. #20
    Oct 2020
    Bulgaria
    why not, i dont have carprog, but i read this chip so many times with ezp2019, minipro and others..
  7. #21
    Smart66's Avatar
    Dec 2020
    I've already tried it on vw cluster but it didn't work because dump read was wrong. Desoldering E2P is always the safest option and must always work
  8. The Following User Says Thank You to Smart66 For This Useful Post:
    auto80 (24th January, 2025)
  9. #22
    Feb 2025
    Default EZP 2023 problem for me. Please help
    Did any one use ezp 2023 ? If do can you tell me how to reset odometer? I don't know where edit it. Please help
  10. #23
    Sep 2024
    is better remove the eeprom and after read post the file in a new thread write number eeprom, km orig and new km you need
