Results 1 to 3 of 3
    Apr 2011
    Default Sprinter 313CDi dpf off 2009
    hi
    please help
    i need dpf off Sprinter 313cdi
    edc16cp31
    0281015052
    i try ECUsafe , volta decoder and some solution but
    not result
    please help
    best regards
    mariusica_boy's Avatar
    Quote Originally Posted by INEGMA View Post
    hi
    please help
    edc16cp31
    0281015052
    not result
    please help
    best regards
    your file is not original...
    here u have restored original + dpf off correct solution
    u can disconnect all sensors related dpf.
    pass in PM
    TUNING - DPF Off - EGR Off - ADBLUE/SCR Off - FLAP Off - TVA Off - DTC Off - LAMBDA Off
    If I helped you please use button Thanks.
  3. The Following User Says Thank You to mariusica_boy For This Useful Post:
    INEGMA (7th August, 2018)
    Apr 2011
    Yes, not the original
    thank you very much
